Старый 10.10.2008, 14:05   #1
palleagermark: Manage Enterprise Portal deployments
Источник: http://palleagermark.blogspot.com/20...ployments.html
In a multi server setup of EP 2009, you could be tempted to install the .NET Business Connector as the only AX part on the IIS.
It turns out that you must also install a regular client, because the "Manage deployments" form only will run from the box where EP is deployed...
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
jinx: Microsoft Dynamics AX 2009 Enterprise Portal Entwicklung Samples Blog bot DAX auf Deutsch 0 27.06.2008 04:06
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 08:44.
