Старый 18.10.2008, 02:08   #1
Kashperuk Ivan: TableBrowser.NET (a small .NET BC tutorial)
Источник: http://kashperuk.blogspot.com/2008/1...-tutorial.html
Here is a Visual Studio solution, demonstrating how the Dynamics AX database can be queried through the .NET Business Connector, and how the results of this can be presented to the user in a user-friendly manner.
Here is a screenshot of how it looks:
You can download the solution on axaptapedia.com.
The class to investigate in the solution is the DynamicsAX class. It provides a pretty good interface for reading data out of Dynamics AX.
After opening the solution, make sure to replace the BusinessConnectorNet.dll, pointing it to your AX installation path (if it is not in GAC)
Kashperuk Ivan: Creating and Posting Inventory ProfitLoss journals in DAX using .NET Business Connector Blog bot DAX Blogs 0 18.01.2008 04:26
Kashperuk Ivan: tutorial_Form_Dynalink (a small tutorial on dynalinks) Blog bot DAX Blogs 0 22.08.2007 17:00
Dynamics AX: Vista, IIS 7 and .Net BC Blog bot DAX Blogs 0 14.06.2007 10:00
Dynamics AX: ASP.Net and the Dynamics AX .net BC Blog bot DAX Blogs 0 05.06.2007 02:28
Kashperuk Ivan: Dynamics AX Tutorials - Tutorial 2 - Classes\Box Blog bot DAX Blogs 0 25.04.2007 22:23
Часовой пояс GMT +3, время: 10:42.
