Старый 25.12.2008, 15:05   #1
mscrm4ever: Change Cases Associated Default View
Источник: http://mscrm4ever.blogspot.com/2008/...ault-view.html
This is a complementary post to the “Changing Activity / History Default View”.
The code sample uses exactly the same concept as the former post so if you’re using that then you should integrate both solution to avoid duplicate functions.
//Case History statecode options
var ServiceOptions =
Active : "0",
Resolved : "1",
Canceled : "2",
All : "All"
var _loadarea = loadArea;
loadArea = function(areaid)
//load the iframe
_loadarea(areaid);
if( areaid != "areaService" ) return;
//create the iframe object
var iframe = document.getElementById(areaid + "Frame");
//wait until the iframe is fully loaded ("complete")
iframe.onreadystatechange = function()
if( iframe.readyState == "complete")
var picklist,option;
//reference to the iframe document
var iframeDoc = iframe.contentWindow.document;
switch(areaid)
case "areaService":
picklist = iframeDoc.all.statecode[0];
option = ServiceOptions.All;
break;
picklist.value = option;
picklist.FireOnChange();
mscrm4ever: Creating a Network Path Text Control Blog bot Dynamics CRM: Blogs 0 21.03.2009 06:43
mscrm4ever: Displaying a lookup with related entity fields Blog bot Dynamics CRM: Blogs 0 19.03.2009 07:05
mscrm4ever: Display Fetch in IFRAME – Part 2 Blog bot Dynamics CRM: Blogs 0 12.03.2009 07:05
mscrm4ever: CRM 4.0 Public View Manager Wizard (Hiding Views) Blog bot Dynamics CRM: Blogs 1 02.03.2009 09:42
mscrm4ever: Displaying an Image in an IFRAME Blog bot Dynamics CRM: Blogs 0 10.02.2009 21:06
Часовой пояс GMT +3, время: 13:42.
