Старый 08.04.2009, 01:06   #1
msdynamicsax: FTP-client within Ax
Источник: http://msdynamicsax.wordpress.com/20...ent-within-ax/
This is a small fix I have done to the WinInet class in Ax, to use it as an ftp-client.
The WinInet class has been removed in Ax2009, but it should work just fine in Ax2009 as well as it’s just a wrapper class for the WinInet.dll
You can test it out using the following job. Remember to check that the firewalls accept this kind of traffic and that you have access etc.
The file should be renamed from .doc to .xpo. Then simply import it to your Ax solution.
class_wininet
ax2009, ftp
msdynamicsax: Quality Assurance for Dynamics Ax-based ERP systems Blog bot DAX Blogs 0 24.03.2009 21:05
msdynamicsax: Dynamics Ax 2009 SDK Blog bot DAX Blogs 0 13.08.2008 14:05
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
msdynamicsax: Dynamics Ax 2009 Demonstration video Blog bot DAX Blogs 0 11.07.2008 20:05
Часовой пояс GMT +3, время: 01:21.
