Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 24.04.2009, 17:51   #1
Hugon is offline
Hugon
AX 4 EmplTable - Please help
Hi All
I have table axtable_1 with some information:
descrition | periodFromDate | periodToDate
and I have field EmplTable.field1 on each employee
empl01 | field1
empl02 | field2 ...
During running EmplTable I need system check axtable_1 and if system date belong to this period, system should put description to EmplTable.field1
Could you help me with this?
Thank you in advance
Hugon
Старый 25.04.2009, 00:04   #2
ZVV is offline
ZVV
MCITP
Oracle
1,006 / 246 (0) ++++++
Сообщение от Hugon Посмотреть сообщение
Hi All
empl01 | field1
empl02 | field2 ...
Hugon
If I've correctly understood your question you just need put some code in update() method of EmplTable.
Smth. like this:
if (<smth>)
   select firstOnly axtable_1
      where axtable_1.periodFromDate <= this.<smth>
           && axtable_1.periodToDate >= this.<smth>;
   if (axtable_1)
      this.field1 := axtable_1.description;
super();
Final version of code (with checks and so on) could you write yourself, I'm sure..
Старый 25.04.2009, 00:40   #3
Hugon is offline
Hugon
Thank you for your help.
This works when you save EmplTable. I need something when I am opening EmplTable, Probably I will need put some code on form not on table
Hugon
Старый 26.04.2009, 00:49   #4
raz is offline
raz
NavAx
Аватар для raz
NavAx Club
1,505 / 1098 (40) ++++++++
You should use a display method on EmplTable and show this method in grid.
display field1_EDT myfield1(EmplTable _emplTable)
    field1_EDT   field1;
    if (<smth>)
          where axtable_1.periodFromDate <= _emplTable.<smth>
              && axtable_1.periodToDate >= _emplTable.<smth>;
       if (axtable_1)
          field1 = axtable_1.description;
    else
          field1 = smth;
    return field1;
За это сообщение автора поблагодарили: Hugon (1).
Старый 27.04.2009, 12:40   #5
Hugon is offline
Hugon
Thumbs up
Brilliant! This works now.
Hugon
ax4.0
Часовой пояс GMT +3, время: 13:59.
