Старый 04.05.2009, 14:05   #1
MS Dynamics Ax and More: How to start a specific Batch Group during Startup
Источник: http://dynamicsandmore.spaces.live.c...4CB0!305.entry
Right now it is not possible to start a specific batch group with a startup command. You certainly can start the batch processing, but within the standard applications it is not possible to start one or more specific batch groups. The problem is caused by a missing parameter within the "SysStartupCmdBatchRun" class.
Now we add a new method to this class:
container CMHParmInCont()
    container   conParm;
    int         i, j;
    str         parmString;
    conparm = conNull();
    for (i = 1; i 0)
            parmString = substr(parm, i, j-i);
        else
            parmString = substr(parm, i, strlen(parm) -i +1);
            j = i + strlen(parmString);
        conParm += parmString;
    return  conParm;
This method extracts the given batchgroupids from the startup command.
The second and last step is to modify the existing infoRun() method in a way that it starts the different batch jobs:
void infoRun()
    batchRun        batchRun = new batchRun();
    BatchGroupId    groupId;
    container       conParm;
    int             i;
    batchRun.parmUseForm(true);
    if (parm)
        parm    = strrem(parm, ' ');
        conParm = this.KBSParmInCont();
<div><font face="Courier New, Courier, Monospace">        for (i = 1; i
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
axaptabuilder: How to make Dynamics AX interface more user friendly with Tabax? Blog bot DAX Blogs 0 12.04.2007 16:10
MS Dynamics Ax and More: How to start a specific Batch Group during Startup Blog bot DAX Blogs 0 28.10.2006 16:47
axaptabuilder: How to make Dynamics AX interface more user friendly with Tabax? Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 00:44.
