Старый 28.05.2009, 19:05   #1
palleagermark: Product builder performance tip
Источник: http://palleagermark.blogspot.com/20...mance-tip.html
I recently had the client/server trace on, while opening the production builder configuration form. Boy, I wish I didn't…
Depending on how complex your product model is, this for generates an excessive number of calls between the client and server.
In my case, the largest group of calls was calls made to \Data Dictionary\Tables\PBALanguageTxt\Methods\label.
The method is tied to be executed on the server, with the "server" keyword.
But, the table itself is cached as EntireTable, and this means that the client is likely to holds its own cache of the values and thus there is no need, and in particular, no gain of forcing AX to run the method on the server.
When I remove the "server" keyword from this method, I get rid of the majority of client/server calls while opening and navigating in this form.
There is however still room for improvement, as the form still generates a huge amount of calls.
Microsoft Dynamics CRM Team Blog: Performance Testing using DbPopulator Blog bot Dynamics CRM: Blogs 0 21.02.2009 06:28
Microsoft Dynamics CRM Team Blog: Tips for faster and better performance on Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 17.01.2009 00:05
Microsoft Dynamics CRM Team Blog: Reports for CRM 4.0 using SQL Server 2008 and Report Builder 2.0 Blog bot Dynamics CRM: Blogs 0 11.11.2008 08:05
AX UK: New Process for Collecting Product Suggestions Blog bot DAX Blogs 0 21.08.2007 16:50
Product Builder: "Модель продукции не существует" Hamster DAX: Функционал 4 17.03.2004 17:46
Часовой пояс GMT +3, время: 10:40.
