Старый 10.07.2009, 10:05   #1
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 2 is available on Partner Source and Customer Source!
Источник: http://blogs.technet.com/dynamicsaxs...er-source.aspx
To assist our partners and customers in their new Microsoft Dynamics AX deployments, the SE team started releasing roll-ups for Microsoft Dynamics AX 2009 RTM and SP1 platforms. The roll-ups aim to provide an easy way of deploying Microsoft Dynamics AX with the latest hotfixes on a given Service Pack level. Roll-up 2 for AX2009 RTM and SP1 has been available on Partner Source and Customer Source as of June 29th, 2009. Please find the roll-up KB articles below:
Roll-up
KB Number
Package Size
Dynamics AX 2009 RTM RU-2 KB Article
KB971535
~60MB
Dynamics AX 2009 SP1 RU-2 KB Article
KB971536
~80MB
There will be one roll-up package for each Service Pack level. Each roll-up will carry all previously released hotfixes up to one month prior to the release of the roll-up and country specific updates. Each roll-up will be cumulative and will not require the presence of the previous roll-up on the system.
The roll-up package will contain both a cumulative kernel update and a cumulative application update. Although there is no dependency between these two updates, we recommend that you install both of the updates together. The roll-up will be installed on P-layers (i.e. SYP and GLP) and update the SYS layer as well as the GLS layer that is installed on the system.
AX UK: Microsoft Dynamics AX 2009 Management Pack for Systems Center Operations Manager (SCOM) 2007 Blog bot DAX Blogs 0 23.06.2009 03:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 1 is available on Partner Source and Customer Source! Blog bot DAX Blogs 0 15.04.2009 10:05
Dynamics AX: AMR Research: Awakening a Sleeping Giant - Inside Microsoft Business Solutions' ERP Strategy Blog bot DAX Blogs 0 22.09.2008 22:05
Часовой пояс GMT +3, время: 09:43.
