Старый 18.07.2009, 02:28   #1
C# and AX Development: Updating the caller Form/DataSource
Источник: http://olondono.blogspot.com/2009/07...atasource.html
If we need to notify events to the caller form we can try this pattern:
In the child form, make a method named updateCaller and invoke it when you want to notify the parent:
void updateCaller(){ Common common; Object dataSource; Object caller; ; //----------------------------------- //We are notifying using the dataSource common = element.args().record(); if (common && common.isFormDataSource() && formDataSourceHasMethod(common.dataSource(), identifierstr(SomethingWasHappend))) { dataSource = common.dataSource(); dataSource.SomethingWasHappend(); } //----------------------------------- //----------------------------------- //We are notifying using the form caller = element.args().caller(); if (caller && classidget(caller) == classnum(SysSetupFormRun) && formHasMethod(caller, identifierstr(SomethingWasHappend))) { caller.SomethingWasHappend(); } //-----------------------------------}
Implement the handling method in the parent form:
void SomethingWasHappend(){ ; info("Something was happend (Form)");}
Or if you prefer, in the DataSource:
void SomethingWasHappend(){ ; info("Something was happend (DataSource)");}
Invoking it from a simple button inside the child form:
void clicked(){ super(); element.updateCaller();}
See a pratical sample in the form MarkupTrans (DataSource -> method write).
Часовой пояс GMT +3, время: 11:41.
