Старый 26.07.2009, 15:07   #1
emeadaxsupport: Kerberos authentication issues in a multi server environment affecting the KPI web part
Источник: http://blogs.msdn.com/emeadaxsupport...-web-part.aspx
When you are setting up Dynamics AX 2009 Role Center and Enterprise Portal in a multi server environment where each component is running on Windows Server 2008 you can get confronted with an authentication issue.
The base requirement for a multi server scenario to work is to use Kerberos authentication and configuring Service Principle Names (SPNs) for the Service Accounts in use (like the Business Connector Proxy Account) otherwise the whole scenario will not work at all.
However even if Kerberos and SPNs are configured correctly you can run into an authentication issue, if you have the following components running on their own server with Windows Server 2008 as operating system:
  • Microsoft SQL Server (including Database Engine, Reporting Services and Analysis Services)
  • Microsoft Office SharePoint Server (or Microsoft Windows SharePoint Services)
  • Microsoft Dynamics AX Application Object Server (AOS)
When users are browsing at Role Center or Enterprise Portal pages they will get errors for the KPI web parts, but Reporting Services reports are shown also those reports that are based on Analysis Services data. The fact that only KPI web parts are affected makes this issue special from regular Kerberos authentication issues, as here also Analysis Services reports would be affected.
Although the KPI web part and the Reporting Services reports (based on Analysis Services data) are accessing the same Analysis Server Database, the way how the Analysis Services are accessed is different:
KPI web part: SharePoint Analysis Services
Reporting Services web part: SharePoint Reporting Services Analysis Services
Microsoft SQL Server Analysis Services
has an issue when running on an "Advanced Encryption Standard (AES)" aware operation system (like Windows Server 2008) and using Kerberos for authentication. If the Microsoft SQL Server Reporting Services and Microsoft SQL Server Analysis Services would be installed on different servers (with Windows Server 2008 as operating system) Microsoft SQL Server Reporting Services would also run into similar issues!
The following BLOG post is discussing this in greater detail and shows also workarounds how to get the scenario to work:
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Microsoft Dynamics CRM Team Blog: Trust for Delegation in List Web Part for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 15.01.2009 03:13
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Часовой пояс GMT +3, время: 20:45.
