Старый 05.08.2009, 13:02   #1
Kent is offline
Kent
XML Declaration
Hello!
I have a problem. How to get the second line in xml document? (text in bold) I can't create element, because element can be only full word witout spaces and other incorrect simbols.
<?xml version="1.0" encoding="utf-8"?>
<DocName xmlns:xsi="http://www.w3.org/2001/XMLScheme-instance" >
</DocName>
Thanks. You can answer in Russian.
Последний раз редактировалось Kent; 05.08.2009 в 13:05.
xml
X++: Serializing Axapta Foundation Class instances as XML streams Blog bot DAX Blogs 0 04.06.2009 23:05
PatrickChua: XML serialization Blog bot DAX Blogs 0 04.05.2009 14:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Inside Dynamics AX 4.0: The XML Structure Blog bot DAX Blogs 0 04.10.2007 11:20
Часовой пояс GMT +3, время: 12:50.
