Старый 13.09.2009, 01:28   #1
X++: Transforming X++ code to managed code: Check the video...
Источник: http://blogs.msdn.com/x/archive/2009...aged-code.aspx
The channel 9 video:
http://channel9.msdn.com/posts/Charl...tor-X-to-MSIL/
showcases some work that the X++ team has done to investigate the options for transforming X++ code into managed code. We are publishing it here in the hope that it may spark some interesting discussions and feedback.
Even though we are passionate about this work, you should not infer that this feature will be available in the next version of Ax, or that we will not continue to focus on the development of the X++ language per se: In fact, we remain commited in our efforts to mature the X++ language, to assure that it continues to provide value to the application developer community.
Let us know what you think!
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
Solutions Monkey: Passing parameters from Managed code to X++ in dataset Blog bot DAX Blogs 0 15.05.2009 09:06
Issues concerning X++: CLR interop: Passing Int16 values to managed code. Blog bot DAX Blogs 0 03.07.2007 00:31
Часовой пояс GMT +3, время: 06:02.
