Старый 05.10.2009, 20:05   #1
25,643 / 848 (80) +++++++
Dynamics CRM Tools: Important Update : View Layout Replicator
Источник: http://mscrmtools.blogspot.com/2009/...eplicator.html
Hi,
This post to warn you about the existing version of ViewLayoutReplicator.
You can experience troubles with your lookup fields when browsing for records if you have replicated a public view to the search view of the lookup related entity.
The behavior is the following:
When selecting a record from the search window, the lookup field just contains the icon of the entity and not the primary attribute as the result of the selection. This is due to the "preview" attribute of the search view that should be "0" (and not "1" which happens if you used the ViewLayoutReplicator as described above).
To correct this behavior, simply download the new version of the tool and replicate the view again.
Microsoft Dynamics CRM Team Blog: Update Rollup 2 for Microsoft Dynamics CRM 4.0 - More Info Blog bot Dynamics CRM: Blogs 0 12.02.2009 13:05
Microsoft Dynamics CRM Team Blog: Update Rollup 2 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 20.01.2009 21:05
Часовой пояс GMT +3, время: 09:48.
