Старый 05.01.2010, 19:16   #1
25,643 / 848 (80) +++++++
Solutions Monkey: EP Tips-n-Tricks - Data Sets / Data Sources
Источник: http://blogs.msdn.com/solutions/arch...a-sources.aspx
Happy New Year !!!
Data Sets
Init
For checking arguments passed from managed code or context and adding ranges/ modifying query.
if (element.args().dataset() == tablenum(EPPriceCalc))
epPriceCalc = element.args().record();
custTable = CustTable::find(epPriceCalc.AccountNum);
priceTransferParmId = epPriceCalc.ParmId;
Pack/UnPack
Persisting values of in-memory variables between postbacks
public container pack()
return [#CurrentVersion, #CurrentList] + [super()];
public boolean unpack(container _pack)
Integer version = conpeek(_pack,1);
container base;
boolean ret;
switch (version)
case #CurrentVersion : [version, #currentList, base] = _pack;
ret = super(base);
break;
default: super(_pack);
return ret;
Other Methods
Also common methods that could be called from Managed code or from other methods in the Data sources could be added at the DataSet level.
Args
Get external arguments through the args objects
Checking for RecordContext
public void init()
super();
EPPersonalize::find(curuserid());
if (element.args() && element.args().dataset() == tablenum(EmplTable))
callerEmplTable = element.args().record();
emplId = callerEmplTable.EmplId;
Passing parameters from Managed code to X++ in dataset
protected<SPAN style="mso-bidi-language: TA"> void Page_Init(object sender, EventArgs e)
this.AxDataSource1.CreatingDataSetRun += new EventHandler(AxDataSource1_CreatingDataSetRun);
Set the param value to the event arugments
void AxDataSource1_CreatingDataSetRun(object sender, CreatingDataSetRunEventArgs e)
e.DataSetRunArgs.parm = "4000";
In AOT override or add method in the data set and use element.args().parm() to received the paramter
public void executeQuery()
QueryBuildRange custRange;
custRange = SysQuery::findOrCreateRange(this.query().dataSourceNo(1), fieldnum(CustTable, AccountNum));
custRange.value(element.args().parm());
super();
You can also pass an Enum. For example
e.DataSetRunArgs.parmEnumType = EnumMetadata.EnumNum(this.AxSession, "EPFormAction");
e.DataSetRunArgs.parmEnum(2);
public void init()
super();
if (element.args().parmEnumType() == enumnum(EPFormAction) && element.args().parmEnum() == EPFormAction::CreateMode)
//do somethign here
Data Sources
Set the below properties at the individual datasources.
InsertAtEnd : No
InsertIfEmpty : No
Also set Allow* properties on the Data source appropriately.
Init
Adding ranges
public void init()
super();
qbrName = this.query().dataSourceTable(tablenum(InventDimCombination)).addRange(fieldnum(InventDimCombination,Name));
qbrName.status(RangeStatus::Hidden);
qbrItem = this.query().dataSourceTable(tablenum(InventDimCombination)).addRange(fieldnum(InventDimCombination,ItemId));
qbrItem.status(RangeStatus::Hidden);
Setting temporary table mode
public void init()
super();
//BP Deviation documented
salesTable.setTmp();
InitValue
Initializing values
public void initValue()
super();
// Is form called with a record
if (element.args() && element.args().record())
callerRecord = element.args().record();
// Init opportunity from lead record
if (callerRecord.TableId == tablenum(smmLeadTable))
smmCreateEntity::initFromCommon(callerRecord, smmOpportunityTable);
info(DirParty::toolTip(smmOpportunityTable));
ValidateWrite
For validation that are specific to the dataset. ( common table level validation could be at the table level)
public boolean validateWrite()
#VendRequest
boolean ret;
ret = super();
if (ret && !VendTable::find(vendrequest.AccountNum))
ret = checkFailed(strfmt("@SYS301682",vendrequest.AccountNum));
if (ret && element.args().managedContentItemName() == #VendRequestStatusChangeAddEdit &&
DirPerson::find(vendRequest.ContactParty) == null)
ret = checkFailed(strfmt("@SYS301683",vendrequest.ContactParty));
return ret;
Write
For updating tables not in the data set and reread
public void write()
if (purchLine.RecId)
purchLine.InventDimId = InventDim::findOrCreate(inventDim).InventDimId;
purchLine_ds.setCurrentInventDim();
mapLines.insert(purchLine.RecId, purchLine);
super();
.datasetlookup
For Customizing field lookup. This does not appear in the override method list. But you should be able to manually create this method which will act as override.
void dataSetLookup(SysDataSetLookup sysDataSetLookup)
List list;
Query query;
args = new Args();
list = new List(Types::String);
list.addEnd(fieldstr(ProjTable, ProjId));
list.addEnd(fieldstr(ProjTable, Name));
list.addEnd(fieldstr(ProjTable, Status));
sysDataSetLookup.parmLookupFields(list);
sysDataSetLookup.parmSelectField('ProjId');
// Call query
query = projTimeSheet_ds.getProjectIDQuery();
// Pass the query to SysDataSetLookup so it result is rendered in the lookup page.
sysDataSetLookup.parmQuery(query);
.modified
public void modified()
super();
purchLine.modifyItemDim(inventDim,
fieldnum(InventDim,ConfigId),
InventTable::itemProductDimensionGroup(purchLine.ItemId));
purchLine_ds.setCurrent();
AXDataSourceControl
Make sure only one AXDataSourceControl has Role property set to Provider ( or ProviderConsumer) in your user control. If the user control contains other user control then across all these , only one datasourcecontrol should play the provider role.
Always set EnableViewState and PersistState to True( This is the default. Don’t change it)
AXGridView
1. DataKeyNames must point to a one (or set) of unique fields int the DataSetView.
2. If the user control is playing the Provider Role ( a propert on the AX user control webpart) , then at least one AXDataSourceControl should have the Role property set to Provider or ProviderConsumer and the ProviderView is set.
AXForm
1. Make Sure DataKeyNames set correctly.
2. When Fields are selected for AXGroup using the boundfield designer, sometime the selectedfields are updated to the markup. (Known bug). Update the markup directly and add the boundfields.
3. If the same Axform control is used for different modes than use the EPFormAction parameter set on the WebContent and switch to the right mode
4. Set the DataMember to _Current
5. UpdateOnPostBack is generally set to False. If you need to access the field values entered in the control before the record is persisted in a postback, then set it to true. For example if you want to change the lookup of a second control based on the value entered on the first control, then you would need to set this property.
6. If you are using the Form for Edit operation set AutoGenerateEditButton to true.
protected void Page_Init(object sender, EventArgs e)
this.SetupMode();
private void SetupMode()
switch (this.FormMode)
case ApplicationProxy.EPFormAction.EditMode:
if (this.PageDefinition != null)
this.PageDefinition.pageTitle = Labels.GetLabel("@SYS131104");
this.formVendRequestProfileEdit.DefaultMode = DetailsViewMode.Edit;
this.formVendRequestProfileEdit.AutoGenerateEditButton = true;
break;
default:
this.formVendRequestProfileEdit.DefaultMode = DetailsViewMode.ReadOnly;
break;
8. Derive from AxBaseUserControl if the AxForm control requires RecordContext and should not display any data when there is no record Context.
protected override bool RequiresExternalContext
get
if (this.FormAction == AppProxy.EPFormAction.CreateMode)
return false;
else
return true;
9. Some useful code generally used in AXForm controls
//Web part private
AxBaseWebPart _baseWebpart = null;
//Webpart
AxBaseWebPart BaseWebpart
get
//return the basewebpart if it is not null
if (this._baseWebpart != null)
return this._baseWebpart;
//get the webpart if basewebpart is null
this._baseWebpart = AxBaseWebPart.GetWebpart(this);
//Web part managed content item for the page
Proxy.WebManagedContentItem ContentItem
get
//get the managed content item from the webpart
return this.BaseWebpart == null ? null : this.BaseWebpart.WebManagedContentItem;
private Boolean IsCustomer()
bool isCustomerBool = false;
if (ApplicationProxy.EP.isCustomer(AxSession.AxaptaAdapter))
isCustomerBool = true;
return isCustomerBool;
static AxBoundField GetField(DataControlFieldCollection fields, string name)
foreach (DataControlField field in fields)
AxBoundField boundField = field as AxBoundField;
if (boundField != null && String.Compare(boundField.DataField, name, true) == 0)
return boundField;
return null;
Solutions Monkey: Convergence session: Enterprise Portal Deployment Tips and tricks Blog bot DAX Blogs 0 26.03.2009 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 04:11.
