29.01.2010, 11:05 | #1 |
CRM DE LA CREME! Adding sort order to the custom entities tab for security roles in MS CRM
Источник: http://crmdelacreme.blogspot.com/201...ntity-for.html
============== HI Guys/Girls! We are busy with a huge crm implementation and currently have about 200 custom entities. When we started to look at the security model for the system and it became a nightmare to set the privileges on the security roles as CRM does not sort the custom entities alphabetically. So what to DO? We hack!... How the solution works: Locate the file called edit.aspx located at: [drive]Program Files\Microsoft Dynamics CRM\CRMWeb\Biz\Roles\edit.aspx Between the </div> and the tags at the bottom of the page.(As shown below) </div> XXXXX[Paste it here] Copy and paste the code below into the file *************************** ************************** And there you go!, a neat sort order for all your custom entities. The code can be adopted for the other tabs as well just make a back of your edit.aspx file. This is a unsupported customization!!!!!! Источник: http://crmdelacreme.blogspot.com/201...ntity-for.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
