Старый 19.02.2010, 23:05   #1
Muhammad Ali Khan: Close Service Activity On Create Message In PlugIn
Источник: http://malikhan.wordpress.com/2010/0...age-in-plugin/
Here is a simple code to close the service activity in a MS CRM Plugin.
1: SetStateServiceAppointmentRequest req = new SetStateServiceAppointmentRequest(); 2: req.ServiceAppointmentState = ServiceAppointmentState.Closed; 3: req.ServiceAppointmentStatus = 8; 4: req.EntityId = new Guid(context.OutputParameters["id"].ToString()); 5: SetStateServiceAppointmentResponse resp = (SetStateServiceAppointmentResponse)crmService.Execute(req); But the above code will work perfectly only if the message is Post Update but doesn’t work if the message is Post Create means it doesn’t close the service activity. Strangely, it doesn’t give any error as well. To add to my surprise, if you had configure any plugin on “SetState” or “SetStateDynamic” for serviceappointment even those plugin will be trigger, but the state of the service activity will not change. Why?, i am not sure.
But does this means we cannot close service activity on the “Create” message?, well the trick is to register the above plug-in as Asynchronous mode (as shown below). now the above message will Close the Service Activity even on the Create Message.
Muhammad Ali Khan: Relating/Connecting MS CRM 4.0 Data With Custom External Content Type Data In SharePoint 2010 Blog bot Dynamics CRM: Blogs 0 04.02.2010 13:05
Muhammad Ali Khan: Using Business Connectivity Services(BCS) In SharePoint 2010 For Connecting To MS CRM 4.0 Blog bot Dynamics CRM: Blogs 0 25.01.2010 01:08
Muhammad Ali Khan: Business Connectivity Services (BCS) Using WCF & SharePoint Designer 2010 Blog bot Dynamics CRM: Blogs 0 12.01.2010 04:44
Часовой пояс GMT +3, время: 13:19.
