Старый 10.05.2010, 21:05   #1
emeadaxsupport: Passing UtcDateTime values in extended query syntax
Источник: http://blogs.msdn.com/emeadaxsupport...ry-syntax.aspx
Recently I was looking into the issue of passing UtcDateTime values into a query in X++ using extended query syntax.
First I will just clarify what I mean when saying "extended query syntax":
This is extended query syntax:
('(validUntilDate = %1)', DateTimeUtil::toStr(utcRefDateTime));
This is the regular syntax for ranges:
('%1', queryValue(utcRefDateTime));
As you can see in my examples above, for the regular syntax using queryValue() is fine, but when using the extended query syntax, there are 3 basic rules for utcDateTime values:
- it's necessary to use DateTimeUtil::toStr() to pass utcDateTime values.
- The query string needs to have brackets around it.
- No speechmarks/quotations should be used around the utcDateTime value.
So working example:
queryStr = strfmt(@"((StartDate < %2) && (EndDate < %2) && (validUntilDate = %1))", DateTimeUtil::toStr(2010-01-10T14:00:00), DateTimeUtil::toStr(2010-01-10T17:00:00));
And a failing example with brackets missing:
queryStr = strfmt(@"((StartDate < %2) && EndDate < %2 && (validUntilDate = %1))", DateTimeUtil::toStr(2010-01-10T14:00:00), DateTimeUtil::toStr(2010-01-10T17:00:00));
Failing with speechmarks/quotations:
queryStr = strfmt(@"((StartDate < %2) && (EndDate < '%2') && (validUntilDate = %1))", DateTimeUtil::toStr(2010-01-10T14:00:00), DateTimeUtil::toStr(2010-01-10T17:00:00));
There is an exception to these rules, that is when using 1900-01-01T00:00:00. Most functions in X++ are returning this as NULL when converting to a string but for the extended range syntax to work correctly we need it to be returned as a string, so the following functions cannot be used:
QueryValue()
dateTime2Str()
Global::utcDateTimeNull()
DateTimeUtil::minValue()
So in my environment I have introduced a new global function to make it easier for me to convert utcDateTime values to strings for extended query ranges, called dateTime2strQuery()
static str dateTime2strQuery(utcDateTime _utcDateTime)
str cvtDateTime;
If(_utcDateTime==DateTimeUtil::minValue())
cvtDateTime = '1900-01-01T00:00:00';
else
cvtDateTime = DateTimeUtil::toStr(_utcDateTime);
return cvtDateTime;
So now my working example looks like this:
queryStr = strfmt(@"((StartDate < %2) && (EndDate < %2) && (validUntilDate = %1))", dateTime2strQuery(2010-01-10T14:00:00), dateTime2strQuery(2010-01-10T17:00:00));
За это сообщение автора поблагодарили: samolalex (1).
extended query, extended query syntax, utcdatetime
jinx: Dynamics AX &ndash; Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
emeadaxsupport: How can the Web Proxies get extended programmatically? Blog bot DAX Blogs 0 16.12.2009 18:05
emeadaxsupport: Query execution failed for data set 'Company' Blog bot DAX Blogs 0 28.10.2009 00:06
Microsoft Dynamics CRM Team Blog: Quick Tip: Passing CRM Form values to an IFrame Blog bot Dynamics CRM: Blogs 0 12.09.2008 02:05
Issues concerning X++: CLR interop: Passing Int16 values to managed code. Blog bot DAX Blogs 0 03.07.2007 00:31
Часовой пояс GMT +3, время: 19:33.
