Старый 25.05.2010, 23:05   #1
25,644 / 848 (80) +++++++
emeadaxsupport: AX2009 SecurityProfiler Tool
Источник: http://blogs.msdn.com/b/emeadaxsuppo...iler-tool.aspx
The attached tool tracks what security keys are being used when a user navigates thru the application.
The existing AX class we hook into gets used every time a form or report is opened in AX so the tool will slow performance down – so don’t load this in a production environment.
Also this doesn’t work for menu items that call classes but we don’t expect that to be a big deal.
The tool is useful for sorting out security in a test environment.
In order to use this tool go in as an Administrator that has access to all of the forms and reports in the system:
  1. Import the attached xpo.
  2. Re-launch AX. This step is important because we have added 2 menu items to the Administration menu and they won’t show up until AX is reloaded.
  3. Under Administration go to Security Profiler.
  4. Click the Start Profiling button – and leave this form open.
  5. Navigate to the forms and reports you want to gather security key information about.
  6. Click the Stop Profiling button in the Security Profiler window (the same window opened in step #4).
    a. A form will open showing you all of the security keys that were hit while you navigated thru the system.
    b. To print out the results listed in the report click the Print report button and click the Default button on the print options dialog that opens.
    c. To view your existing security profiles click Administration > Security Profile Results
This tool should not be loaded into a production environment.
emeadaxsupport: AX2009 SecurityProfilerTool Blog bot DAX Blogs 0 21.05.2010 03:05
emeadaxsupport: Possibilities to create Memory Dumps from crashing processes Blog bot DAX Blogs 0 12.05.2010 19:05
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Online Data Import tool Blog bot Dynamics CRM: Blogs 0 05.06.2009 05:10
Default Cube Advisor Tool for Dynamics AX2009 is released kashperuk DAX: Прочие вопросы 0 30.04.2009 19:18
mfp: Migration Tool for Microsoft Dynamics AX 2009 is released Blog bot DAX Blogs 5 25.11.2008 21:37
Часовой пояс GMT +3, время: 00:58.
