Старый 21.07.2010, 22:06   #1
paruvella: De-serialization of string format XML in Dynamics Ax
Источник: http://paruvella.spaces.live.com/Blo...4DB0!546.entry
For some requirements, we need to store XML as a string in some Ax-Tables and need to de-serialize this string field as a document at a later point of time.
During de-serialization process need to store the XML values in to some tables.
The following example will illustrate, how XML string can be read using X++ code.
static void PSReadXMLFileAsString(Args _args)
    XmlTextReader       xmlTextReader ;
    str                 xmlString = ''
                                    +'o130006'
                                    +'260005'
    xmlTextReader = XmlTextReader::newXml(xmlString, true) ;
    xmlTextReader.read() ;
    while(xmlTextReader.read())
        switch (xmlTextReader.NodeType())
                case XmlNodeType::Element: // The node is an element.
                    print ("");
                    break;
                case XmlNodeType::Text: //Display the text in each element.
                    print (xmlTextReader.Value());
                    break;
                case XmlNodeType::EndElement: //Display the end of the element.
                    print ("");
                    break;
     pause;
Часовой пояс GMT +3, время: 19:53.
