Старый 01.08.2010, 19:06   #1
kamalblogs: Using while select firstonly to avoid validations in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
When you execute a select statement to retrieve a single record most of us right the query first. This is followed by a validation to ensure that the query has returned a record. we make it simpler If we right it the way mentioned below…
static void WhileSelectInsteadoFSelect(Args _args)
    InventTable inventTable;
-----General way---------
    //fetch the record first
    select firstonly forupdate inventtable;
    //add an additional validation
    if (inventTable.recid)
        inventTable.itemName = 'newname';
        inventTable.update();
------Alternate--------------
    //prevents the extra 'if' chek
    while select firstonly forupdate inventTable
    //can also be used for simple readonly
    while select firstonly inventTable
        Info(inventTable.ItemId);
A few of you might already follow it but for the rest it could be a learning
Часовой пояс GMT +3, время: 16:49.
