Старый 11.08.2010, 11:05   #1
East Ocean - Technical: The path is not of a legal form - Data Migration Manager
Источник: http://eastoceantechnical.blogspot.c...form-data.html
I received the error message '"The path is not of a legal form" during installation of Data MigrationManager for CRM 4.0
Reason for this error is one of the key's value is empty, to solve this;
  1. Start>run>regedit
  2. Navigate to [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products]
  3. You will see many folder under it named with GUID. If you can see {59DD8CB00184F24E99A62CF4D6109FA}, then click it and goto InstallProperties
  4. Right click InstallLocation and select Modify
  5. Type in "C:\Program Files\Microosft Dynamics CRM"
  6. If you can't find the above mention GUID, you need to browse those GUID one by one and look DisplayName with value "Microsoft Dynamics CRM Server", then just change the InstallLocation value.
Hope this help :)
East Ocean - Technical: CRM 4.0 Update Rollup 10 Blog bot Dynamics CRM: Blogs 0 11.04.2010 19:07
Ошибка при открытии CRM Data Migration Manager kukurechka Dynamics CRM: Администрирование 4 19.02.2010 18:35
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Channel9: Microsoft Dynamics CRM 4.0 : Data Migration Manager with John O'Donnell Blog bot DAX Blogs 0 04.01.2008 23:21
Часовой пояс GMT +3, время: 17:54.
