Старый 20.12.2010, 22:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Print medium change in dialog not working on certain reports
Источник: http://blogs.msdn.com/b/emeadaxsuppo...n-reports.aspx
Recently we were able to solve an issue with the print medium on certain reports. It is not changed immediately in a report print dialog option when it is generated from a class that extends RunBaseReportDialog.
This works fine when printing a standard report without extending from the RunBaseReportDialog class, (i.e, menu item object type is report).
The problem was caused by the following code line in method Classes/RunBaseReportDialog/main().
The prompt is called from the reportRun object instead of the reportDialog object .
res = reportRun.prompt();
To solve the problem we therefore had to change the code line like this:
res = reportDialog.prompt();
author: Sendil Kumar editor: Daniel Durrer date: 20/Dec/2010
emeadaxsupport: Working with CLR Exceptions in Dynamics AX X++ code Blog bot DAX Blogs 0 22.07.2010 19:06
emeadaxsupport: Cost accounting journal excel import dialog fails to appear COSExcelImport Blog bot DAX Blogs 0 29.05.2010 03:18
emeadaxsupport: Dynamics AX Reporting Services Reports does not refresh after refreshing Role Center page Blog bot DAX Blogs 0 03.04.2010 05:15
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 13:48.
