Старый 29.12.2010, 02:16   #1
25,644 / 848 (80) +++++++
dax-ideas: Creating a SalesOrder through .net applications or BC classes
Источник: http://dax-ideas.blogspot.com/2010/1...rough-net.html
Sometimes it would be necessary for us to create the SalesOrder through the .net application or some third party application at that time we need to make use of BC classes to create SalesOrder. Here is a small snipeet for creating the salesOrder through AXBC classes.
static void salesOrder(Args _args)
        AxSalesTable axSalesTable;
       AxSalesLine axSalesLine;
       AxInventDim_SalesLine axInventDim;
       NumberSequenceReference numberSequenceReference;
       NumberSeq numSeq;
       SalesTable salesTable;
       SalesId salesId;
       ttsbegin;
       numberSequenceReference = SalesParameters::numRefSalesId();
       numSeq = new NumberSeq();
       numSeq = NumberSeq::newGetNum(numberSequenceReference,true);
       salesId = numSeq.num();
       axSalestable = AxSalesTable::construct();
       axSalesTable.parmCustAccount('100123');
       axSalesTable.salesTable().initFromCustTable();
       axSalesTable.salesTable().initValue();
       axSalesTable.salesTable().initFromContactInfo();
       info(salesId);
       axSalesTable.parmSalesId(salesId);
       if(!axSalesTable.salesTable().validateWrite())
            numSeq.abort();
            break;
       else
           numSeq.used();
           axSalesTable.save();
        SalesTable = SalesTable::find(salesId);
        axSalesLine = AxSalesLine::construct();
        axSalesLine.parmSalesId(salesId);
        axSalesLine.salesLine().initValue();
        axSalesLine.salesLine().initFromSalesTable(SalesTable);
        axSalesLine.parmItemId('1121');
        axInventDim = AxInventDim_SalesLine::newAxSalesLine(axSalesLine);
        axInventDim.parmInventSizeId('42');
        axInventDim.parmInventLocationId("21");
        axInventDim.parmConfigId("HD");
        axInventDim.parmInventColorId('01');
        axInventDim.parmInventSiteId('2');
        axInventDim.setInventDimId();
        axSalesLine.axInventDim(axInventDim);
        axSalesLine.save();
        ttscommit;
axbc
dax-ideas: Creating a new form using code Blog bot DAX Blogs 0 23.12.2010 20:11
dax-ideas: Creating a new Item through Code Blog bot DAX Blogs 8 18.11.2010 19:52
Arijit Basu: DAX 4.01 .NET Business Connector: Microsoft.Dynamics.BusinessConnectorNet Blog bot DAX Blogs 3 30.09.2008 01:17
Передача функции в качестве параметра lemchey_white DAX: Программирование 20 21.01.2008 22:51
Kashperuk Ivan: Creating and Posting Inventory ProfitLoss journals in DAX using .NET Business Connector Blog bot DAX Blogs 0 18.01.2008 04:26
Часовой пояс GMT +3, время: 00:01.
