Старый 25.01.2011, 22:11   #1
axblog4u: Multiple XPO Import Version – 2
Источник: http://axblog4u.wordpress.com/2011/0...ort-version-2/
Hi folks ,
There was a major issue in the version 1 of the Multiple XPO Import tool. Each time when a multiple XPO’s are imported, a confirmation dialog keeps popping up for all the existing elements. This behavior seems to be very annoying to the users.
Now the code design pattern is slightly modified. When an import is performed all the objects are imported SILENTLY without confirmation dialog show up to users even for existing elements.
Note: Please use at your own risk when trying on Production environment
If you still wanted to get confirmation dialog for existing element please use the Version – 1 link:
http://axblog4u.wordpress.com/2010/1...r-dynamics-ax/
I have a made minor changes w.r.t existing version.
1) No Email support.
Instead, once the objects are imported the log file is opened automatically.
2) The log report shows the Imported User & User Preferred Time zone.
In the vNext – 3, I shall be adding new feature like:
1) Adding the imported object to the Project at run-time so that user can track the imported objects based on the time.
Download Link @ Version: 2
http://cid-264a0056cbcbb1d3.office.live.com/self.aspx/.Public/SharedProject%5E_MultipleXPOImport%5E_v2.xpo
Dynamics Ax: Multiple XPO Import Tool for Dynamics AX Blog bot DAX Blogs 0 09.11.2010 19:10
Удаленная работа с CRM и расширеный поиск ASheff Dynamics CRM: Разработка 64 04.06.2010 17:44
kamalblogs: Solving the Id conflict issue during import of XPO in Dynamics Ax Blog bot DAX Blogs 2 03.05.2010 07:20
Часовой пояс GMT +3, время: 02:18.
