Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 02.02.2011, 20:43   #1
ist is offline
ist
Ax and touch screen
Hi, Guys
I have a form similar to(see attachment). User will interact with the form through touch screen without keyboard and mouse. How can I simulate a keypress when the user touches the button on the form?
10x in advance
Изображения
Старый 03.02.2011, 08:23   #2
S.Kuskov is offline
S.Kuskov
3,449 / 1792 (66) ++++++++
Сообщение от ist Посмотреть сообщение
Touching is a mouse click. You have a different?
Старый 03.02.2011, 09:17   #3
kornix is offline
kornix
414 / 146 (5) +++++
Hi, Guys
10x in advance
Hi!
I think you can use your mouse, if you'll click on buttons in your form in Dynamics you can simulate and debug your action. The method which called when users press buttons on your form is "clicked" independent of the way of pressing
Старый 03.02.2011, 13:29   #4
ist is offline
ist
Сообщение от kornix Посмотреть сообщение
Hi!
I know but, I have another idea: to use the task method on the form and for example if the user touches button 7, in the click method to do:
void clicked()
    super();
    ctrl_InputQuantity.setFokus();
    element.task(#Key7); // simulate key 7 pressed
My goal is: when the ctrl_InputQuantity is in focus, I hope that it could catches keypress 7
Regards,
Старый 04.02.2011, 11:12   #5
kornix is offline
kornix
414 / 146 (5) +++++
ist, Hi!
Your idea is good, but i think you can't simulate button click by this method. You can try to place breakpoint in task() method in your form like this:
public int task(int _taskId)
    int ret;
    ret = super(_taskId);
    breakpoint;
    return ret;
In this example when i clicked by mouse on buttons form (left clicked), i can't step in this method in debugger. But if i'll use keyboard, system should step in with _taskId parameter.
Старый 04.02.2011, 12:43   #6
S.Kuskov is offline
S.Kuskov
You can use WinAPI:
#WinAPI
#KeyPressed
void clicked()
    super();
    ctrl_InputQuantity.setFocus();
    ctrl_InputQuantity.setSelection(-1,0);
    WinAPI::postMessage(ctrl_InputQuantity.hWnd(), #WM_KEYDOWN, #Key7, 0);
Старый 04.02.2011, 17:13   #7
ist is offline
ist
You can use WinAPI:
#WinAPI
#KeyPressed
void clicked()
    super();
Thanks a lot, it works perfect. The bad news is thah in the #KeyPressed I didn't found comma macro. I have noticed that some macroses coincides with ASCII code of the characters. I try with ASCII code 44 that is ASCII code of the comma character, but without success.
WinAPI::postMessage(ctrlQty.hWnd(), #WM_KEYDOWN, #Comma, 0);
Последний раз редактировалось ist; 04.02.2011 в 18:50.
Старый 05.02.2011, 02:12   #8
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
I believe WM_KEYDOWN message's wParam parameter is a virtual-key code, not an ASCII-code. VK_OEM_COMMA value is 0xBC.
Старый 05.02.2011, 22:12   #9
ist is offline
ist
Thank's a lot.
Kurt Hatlevik: Warehouse Management and Distribution for Dynamics AX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
Dynamics AX: Microsoft - The Next Big ERP Innovator Blog bot DAX Blogs 2 02.04.2009 18:55
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
Kurt Hatlevik: Warehouse Management and Distribution for Dynamics AX 2009 Blog bot DAX Blogs 0 20.11.2008 01:10
Dynamics AX: Interview with Steen Andreasen 2007 Blog bot DAX Blogs 0 19.09.2007 21:42
Часовой пояс GMT +3, время: 14:14.
