Старый 07.02.2011, 16:11   #1
axzaptech: Delete Action
Источник: http://axzaptech.wordpress.com/2011/...delete-action/
Cascade
A cascading delete action will delete all records in the related table, where the foreign key is equivalent to the primary key of the current table. That is, deleting the parent record will also delete the child record(s) in the related table. This cascading will take place whether the deletion is performed in code or directly by a user through the user interface.
Restricted
A restricting delete action will raise an error message if the user tries to delete a record, where records exist in the related table where the foreign key is equivalent to the primary key of the current table. This error will only appear if the deletion is performed through the user interface. A deletion from X++ code will be allowed to proceed and will not be cascaded to the related table. In this case the programmer should call .validateDelete() themselves prior to the call to .delete()
Cascade + Restricted
The delete action performs a restricted, if the record of the table will be deleted directly and performs a cascade, if the record of the table will be deleted through a cascade delete action of a other table.
Thanks for reading. keep visiting and giving feedback.
axzaptech: Working with Multiple Datasource on a single Form Blog bot DAX Blogs 0 28.01.2011 23:14
Microsoft Dynamics CRM Team Blog: Leveraging bulk delete jobs to manage System Job log records Blog bot Dynamics CRM: Blogs 0 13.11.2008 22:06
Delete Action. Максимальное кол-во таблиц. custtable DAX: Программирование 5 08.09.2008 17:49
Не работает Delete Action в таблице Dimension duz DAX: Программирование 0 02.02.2006 08:47
Отображение связных таблиц. Сплиттер. Автоувеличение индекса. Delete Action. sguryev DAX: База знаний и проекты 0 14.12.2001 06:15
Часовой пояс GMT +3, время: 20:16.
