Старый 03.08.2011, 09:11   #1
sumitax: Upgrade scripts AX 4.0 to AX2009 Upgrade -Post synch step
Источник: http://sumitax.wordpress.com/2011/07...x2009-upgrade/
Following are steps to write upgrade scripts :
  1. Get a summary of field Id changes between 4.0 and 2009 from SQLDictionary Table in both version.
  2. Create a copy of SQL Dictionary table from 4.0 Version  and import this Table in AX2009 Database.
  3. Now create a view to compare the field id for fields with same name,same Table name ion both versions.
  4. Now modify ReleaseUpgradeDb3X_Module or ReleaseUpgradeDb4X_Module and add the old field Ids for addPostsyncsjobs method.
  5. Now run the PostSync step . This will resolve the field Id difference issues.
sumitax: CRM – Changes between AX 4.0 and AX2009 Version Blog bot DAX Blogs 0 03.08.2011 09:11
sumitax: AX4.0 to AX2009 Upgrade Back to Basics Blog bot DAX Blogs 0 29.06.2011 19:12
Sample Design Patterns: Upgrade to Microsoft Dynamics AX 2009 and issues with the global address book Blog bot DAX Blogs 0 21.12.2010 11:11
DynamicsAxSCM: Quality Management in Dynamics AX 2009 - Upgrade essentials Blog bot DAX Blogs 0 16.12.2008 14:05
Часовой пояс GMT +3, время: 22:28.
