Старый 07.09.2011, 17:11   #1
25,644 / 848 (80) +++++++
Gareth Tucker: Utilising some of Microsoft CRM 2011’s Hidden Functions
Источник: http://gtcrm.wordpress.com/2011/09/0...den-functions/
I stumbled across this today.  Not sure if this is common knowledge. It is likely not supported. It is however interesting.
Today I wanted to save an Activity record as completed and close the form all via java script.  i.e. I wanted to be able to do the same thing that clicking this button does:
I wondered whether the CRM ribbon definition would reveal what this button does.  Sure enough it does.   Looking in…
\sdk\samplecode\cs\client\ribbon\exportribbonxml\exportedribbonxml\phonecallribbon.xml
… I found that the “Mark Complete” button calls a command called:
"Mscrm.SavePrimaryActivityAsComplete"
As you can see below:
This Command is a Ribbon Command and a quick ctrl-F in that same file quickly located the definition of the Command:
As you can see the button calls a Function called “SaveAsCompleted” which resides in a java script library called activity.js.
I wondered whether I could call this function from my java script.   Sure enough I can:
Works exactly as I hoped.
Does this mean I have java script access to lots of additional functionality?  I hope so!
p.s. Another approach that might work here and may be a little more supported is to programmatically click the Ribbon button.  I haven’t tried that.
p.p.s  If you are curious as to what the code behind this function is you can locate it on your CRM server under:  \CRMWeb\_static\Activities
Here it is:
function SaveAsCompleted(){if(!crmForm.IsValid())return;crmForm.SubmitCrmForm(58,true,true,false)}
Regards,
Gareth
Gareth Tucker: Installing the Customer Care Accelerator (CCA) for CRM 2011 Blog bot Dynamics CRM: Blogs 3 23.12.2011 09:16
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 19 Blog bot Dynamics CRM: Blogs 0 26.08.2011 01:13
crminthefield: Microsoft Dynamics CRM 4.0 and 2011 Update Rollup Release Dates, Build Numbers, and Collateral Blog bot Dynamics CRM: Blogs 0 24.08.2011 02:11
Часовой пояс GMT +3, время: 12:37.
