Старый 01.11.2011, 03:13   #1
25,644 / 848 (80) +++++++
Two tricks about stopping AX service via PowerShell
Источник: http://alexvoy.blogspot.com/2011/10/...x-service.html
Generally speaking, it is true for all Windows services but my particular example is about stopping Microsoft Dynamics AX service (AOS) via PowerShell.
As recommended in Deploying customizations across Microsoft Dynamics AX environments white paper, before importing a metadata model store into the target environment, one must stop all AOS instances in it.
First trick is on how to provide the correct name of the service supposed to be stopped.
If you try to use the service name you see in Services, you will fail.
PS C:\Windows\system> Set-Service -name AOS60$01 -status stopped
Set-Service : Service AOS60 was not found on computer '.'.
At line:1 char:12
+ Set-Service -name AOS60$01 -status stopped + CategoryInfo : ObjectNotFound: (.:String) [Set-Service], Invali dOperationException + FullyQualifiedErrorId : InvalidOperationException,Microsoft.PowerShell.C ommands.SetServiceCommand
It is evident that the problem is in $ sign. To fix it you can simply quoted it with "'" (not with "!).
PS C:\Windows\system32> Set-Service -name 'AOS60$01' -status stopped
Unfortunately, this command does not work anyway because of an error:
Set-Service : Cannot stop service 'Microsoft Dynamics AX Object Server 6.0$01-a
x2012_std (AOS60$01)' because it is dependent on other services.
At line:1 char:12
+ Set-Service -name 'AOS60$01' -status stopped + CategoryInfo : InvalidOperation: (System.ServiceProcess.Service Controller:ServiceController) [Set-Service], ServiceCommandException + FullyQualifiedErrorId : ServiceIsDependentOnNoForce,Microsoft.PowerShell .Commands.SetServiceCommand
Nevertheless, you can stop the service as usual without any issue. I do not why it does not work but I would suggest that one use another commands to stop and start the service, namely:
PS C:\Windows\system32> Stop-Service 'AOS60$01'
WARNING: Waiting for service 'Microsoft Dynamics AX Object Server
6.0$01-ax2012_std (AOS60$01)' to finish stopping...
PS C:\Windows\system32> Start-Service 'AOS60$01'
6.0$01-ax2012_std (AOS60$01)' to finish starting...
It takes its time, be patient!
Старый 01.11.2011, 17:24   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Сообщение от Blog bot Посмотреть сообщение
gsv aos* | ft -au
еще можно эскейпить так
spsv aos60`$01
но я просто пользуюсь звездочкой
sasv aos6*01
Старый 02.11.2011, 21:25   #3
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
что делают эти три команды? (жаль, обратно в блог отсюда комменты не ходят)
Felix nihil admirari
Старый 03.11.2011, 08:49   #4
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
С целью краткости использованы алиасы - для того чтоб выяснить что они означают можно написать либо
gsv -?, либо help gsv, либо поискать в хелпе - который по f1 в Powershell ISE
1. С целью узнавания имени АОСа получаем список всех сервисов, имя которых начинается с aos (лично мне лениво лазить в панель управления а ISE у меня обычно и так открыт). Так как по умолчанию DiaplayName обрезается по некоторой длине выхлоп gsv передается командлету Format-Table с опцией -AutoSize (в powershell опции можно указывать не полностью а по первым буквам - главное, чтобы эти буквы определяли ровно одну опцию - тут можно было ограничится и -a)
gsv aos* | ft -au
2. spsv стандартный алиас для Stop-Service а символом ` можно искейпить одиночные символы
spsv aos60`$01
3. sasv == Start-Service. мне обычно проще нажать звездочку чем `. Так как обычно аосов не больше десятка я запускаю так
sasv aos6*1
см также http://axaptapedia.com/index.php?title=PowerShell
За это сообщение автора поблагодарили: gl00mie (2).
Старый 03.11.2011, 18:26   #5
wojzeh is offline
wojzeh
Аватар для wojzeh
ты крут! как, впрочем, и все апологеты командной строки. а вот скажи мне, стоит ли ожидать более человеческого интерфейса в этом нелёгком деле?
Старый 05.11.2011, 09:51   #6
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
уже есть
За это сообщение автора поблагодарили: wojzeh (1).
Старый 05.11.2011, 18:24   #7
wojzeh is offline
wojzeh
Аватар для wojzeh
макс, спасибо за ссылку! правда, я имел в виду какой-нибудь интерфейс к powershell.
Старый 06.11.2011, 21:54   #8
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
я пользуюсь только Powershell ISE из комплекта (c CTP3 никаких проблем не заметил кроме отсутствия хелпа)
Знаю еще powergui и
http://code.google.com/p/farnet
powershell
DynamicsAxSCM: Service products in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 2 02.06.2011 13:36
Часовой пояс GMT +3, время: 03:47.
