Старый 16.11.2011, 15:11   #1
workflowax: How do I select from table Common in AX?
Источник: http://workflowax.wordpress.com/2011...-common-in-ax/
Workflow quite often uses fields such as ContextTableId and ContextRecId to reference the original document. I’ve been needing to get hold of the original database record as a Common object from which I can then do various things, but the question is how do i get that common object?
I’ve tried something like this
Common buffer;
select buffer where buffer.TableId == _tableId && buffer.RecId == _recId;
This however always return an empty buffer regardless of whether or not the record does exist. I eventually managed to retrieve a common record with the following method.
Common buffer;
SysDictTable dictTable;
dictTable = new SysDictTable(_tableId);
buffer = dictTable.makeRecord();
select buffer where buffer.RecId == _recId;
I’ve needed to do this a couple of times in the past and kept forgetting, so I’m posting it here for myself and who ever else wants to accomplish this. Enjoy!
Последний раз редактировалось Poleax; 16.11.2011 в 17:42. Причина: оформление
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
workflowax: How to run multiple Dyanamics AX workflow websites on IIS 7 Blog bot DAX Blogs 0 10.12.2010 18:11
Часовой пояс GMT +3, время: 22:31.
