Старый 22.12.2011, 04:24   #1
25,644 / 848 (80) +++++++
gustafwesterlund: Problems with converting email to case
Источник: http://gustafwesterlund.blogspot.com...l-to-case.html
I was recently working with a customer when I noticed an interesting bug in CRM 2011, in the Outlook Client. When trying to convert an email to either a lead, case or opportunity directly from the Outlook ribbon, it does not set the "regarding" lookup field of the email that was tracked. However, if the email is first tracked, then "viewed in CRM" and then from the CRM email form converted to lead, case or opportunity, the regarding field is set correctly.
To make this a bit more clear I will describe this with a few screenshot below:
We'll start off with opening a received email and pressing the Track button in CRM
This will then allow us to press the convert to Opportunity, Case or Lead, directly from Outlook. A very neat, and new function. It came with CRM 2011. In this example, I am selecting Case.
This will show a smaller dialog allowing you to select case (not shown here) and also prompting you if you want to open the case or not. I selected to open the case.
After opening the case, I checked the closed activities to see if the attached email that was I just converted to a case, but as you can see below there were none. I was a bit perplexed as I was showing this new functionality to the customer as was expecting to see the email here.
I went back to the email from Outlook and opened it in CRM and found that it had not been correctly connected to the case using the lookup "Regarding" field.
So, I tried it the old way. I sent myself another email, pressed the track in CRM button, and then instead of converting it directly from Outlook, i pressed the "View in CRM" button to open it in CRM.
I then converted it to a case from the ribbon menu from the CRM Email from by pressing the "To Case" button.
I was shown a similar small dialog letting me select subject for the case and similar and then the case form was shown. It was identical to when created from Outlook, but when checking the closed activities there was one important difference;
And by opening the CRM email form from the list shows it clearly:
The regarding field has been set properly.
This is a very unfortunate bug in CRM and I do hope Microsoft solve it quickly as the feature that CRM 2011 adds in Outlook by being able to convert emails to cases, opportunities and leads directly from the email form is very good but as all of you know who work close to sales or customer service people, their time is very precious and every click counts and new features that do not deliver as expected are always annoying to the user. So, until the bug has been fixed, make sure the users open the CRM form to convert the emails.
Gustaf Westerlund
CEO, Chief Architect and co-Founder at CRM-konsulterna AB
www.crmkonsulterna.se
gustafwesterlund: Problems when connecting PluginRegistration Tool to CRM Blog bot Dynamics CRM: Blogs 0 12.05.2011 21:11
gustafwesterlund: Email router on Windows Server 2008 R2 Blog bot Dynamics CRM: Blogs 0 05.04.2011 06:13
gustafwesterlund: Need to approve email addresses in CRM 2011 Blog bot Dynamics CRM: Blogs 0 22.12.2010 19:11
gustafwesterlund: Problems with referenced assemblies in plugins Blog bot Dynamics CRM: Blogs 1 03.09.2009 14:36
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM, Email correlation and smart matching Blog bot Dynamics CRM: Blogs 0 12.11.2008 04:08
Часовой пояс GMT +3, время: 02:49.
