Старый 12.01.2012, 02:14   #1
25,644 / 848 (80) +++++++
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – owning less than 100% of a subsidiary (Part 7 of 7)
Источник: http://blogs.msdn.com/b/dynamicscpm/...rt-7-of-7.aspx
At times, a company only owns a percentage of another company. In this situation, when producing a consolidated report, it is important to only account for the percentage of ownership you own. Management Reporter uses the Rollup % in the Reporting Tree Definition, and setting this up is outlined in this blog post (the last in a series of blogs on consolidations).
  • Part 1 contains an overview of consolidating data across one or multiple Dynamics ERPs with the same chart of accounts and same fiscal periods.
  • Part 2 describes consolidating across one or multiple Dynamics ERPs with different chart of accounts.
  • Part 3 defines the process for consolidation across one or multiple Dynamics ERPs with different fiscal periods.
  • Part 4 is focused on reporting with multiple Dynamics AX 2009 instances (AOS) and/or if currency translation and eliminations are required.
  • Part 5 will show you how to report on consolidation data that resides in non-Dynamics ERPs.
  • Part 6 will discuss how to produce a consolidated report in Management Reporter that includes a column for elimination entries.
  • Part 7 will focus on scenarios where a company does not own 100% of a subsidiary.
In the Reporting Tree Definition, enter the % of ownership in column K, Rollup %, and when the report is generated, that percentage will be used to calculate the consolidated amount. In this example, Contoso only owns 80% of Contoso Denmark. The user can enter 80 in the column, or .8 and 80% will roll up to the consolidated level.
NOTE: You can apply this ownership percentage to any reporting unit, not just at the company level. This is helpful when ownership is at a business unit or division level, not just a legal entity.
At report generation, Contoso Denmark shows its full amount in the report for Contoso Denmark, and only 80% of it is allocated to the consolidated node. In the following example, at the consolidated level for Sales, you can see only 80% shows.
NOTE: For the month of June, Contoso Entertainment did not have any Sales, so Sales only reflects Contoso Denmark in this case.
If you own less than 1% of a company, select “Allow rollup less than 1%” in the Additional Options tab of the Report Settings form, and then the rollup % in the reporting tree will be treated as less than 1%. For example, if the setting is selected, then .8 would .8%, not 80%. Alternatively, you can also enter .008 and leave the setting cleared.
The series of blogs has covered the many different consolidation scenarios that a company faces during the reporting process. From multiple Dynamics ERPs, to different charts of accounts, to ownership percentage, Management Reporter is designed to fit your consolidation reporting needs.
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – using Management Reporter for eliminations (Part 6 of 7) Blog bot DAX Blogs 0 11.01.2012 01:11
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating with data in a non-Dynamics ERP (Part 5 of 7) Blog bot DAX Blogs 0 10.01.2012 03:14
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating with multiple Dynamics AX 2009 instances (AOS) and/or if currency translation and eliminations are required (Part 4 of 7) Blog bot DAX Blogs 0 07.01.2012 03:18
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating data across one or multiple Dynamics ERPs with different fiscal periods (Part 3 of 7) Blog bot DAX Blogs 0 06.01.2012 01:13
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating data across one or multiple Dynamics ERPs with different chart of accounts (Part 2 of 7) Blog bot DAX Blogs 0 05.01.2012 05:11
Часовой пояс GMT +3, время: 15:17.
