Старый 02.02.2012, 21:11   #1
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting extensions: Error System.Security.Permissions.EnvironmentPermission while running report
Источник: http://blogs.msdn.com/b/axsupport/ar...ng-report.aspx
We run into issue that whenever we used a Microsoft Dynamics AX configuration file with a Reporting Services instance (as mentioned in here: http://technet.microsoft.com/en-us/l.../hh389774.aspx) the following error was reported the first time a report was run after the restart of the SQL Reporting Services instance:
"The DefaultValue expression for the report parameter ‘AX_CompanyName’ contains an error: Request for the permission of type 'System.Security.Permissions.EnvironmentPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed. (rsRuntimeErrorInExpression)"
Running the report for the second time, it renders without any error. The error is mostly seen with subsequent instances of Reporting Services because only then an Microsoft Dynamics AX configuration file (Microsoft.Dynamics.AX.ReportConfiguration.axc) is used but any Reporting Services instance that is set up to use an AX configuration file will throw this error.
The resolution we found was to use "FullTrust" permission set in place of "Execute" for the "Report_Expressions_Default_Permissions" in the rssrvpolicy.config
Existing configuration:
Replacement configuration:
--author: Jolanta Malkowska
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to run reports that executes longer than 10 minutes Blog bot DAX Blogs 0 25.01.2012 10:11
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting Services – Scale-out deployments Blog bot DAX Blogs 0 28.11.2011 00:14
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 16:29.
