Старый 11.04.2012, 18:11   #1
dynamicscpm: How can you get Management Reporter 2012?
Источник: http://blogs.msdn.com/b/dynamicscpm/...rter-2012.aspx
Hopefully, we’ve told you enough about Management Reporter 2012 that you’re wondering how you can get it! Let’s break it down for a couple scenarios….
You’re already using Management Reporter V2…
If you’re already using Management Reporter V2, it’s pretty easy to get Management Reporter 2012. You just need to get going with the download; your existing product registration keys will work on Management Reporter 2012, as well.
We recommend that you contact your Microsoft Dynamics Partner before installing and that you verify that your environment is compatible. We also recommend you run Management Reporter V2 and Management Reporter 2012 side by a side for a while.
You’re using FRx and ready to move to Management Reporter….
If you’ve been holding off on moving to Management Reporter, you probably have now decided that it’s time to move off FRx.
Registration keys for Microsoft Dynamics GP, Microsoft Dynamics SL and Microsoft Dynamics AX
If you’re using Dynamics GP, Dynamics SL or Dynamics AX, the registration keys for Management Reporter have already been added to your Dynamics account and you should be able to look them up on CustomerSource.
Registration keys for Microsoft Dynamics NAV
To obtain registration keys, existing customers, who have an active Business Ready Enhancement Plan (BREP), should contact their Dynamics NAV partner who can place a no-charge order to add Management Reporter, based upon the number of FRx users that you have.
The following table shows the number of Management Reporter users you will receive for each FRx user that you have:
FRx Item Name
FRx Qty
Will Get of Management Reporter
Ratio
FRx Report Designer Users
1
2 - Management Reporter Designer User
1:2
FRx WebPort User
1
2 - Management Reporter Viewer User
1:2
FRx Report Server
1
1 - Management Reporter Viewer User
1:1
FRx Drill Down Viewer
1
1:1
FRx Report Launcher
1
1:1
You should add Management Reporter to your account now, even if you are not yet ready to begin using it. If you are unsure if you have FRx on your account today, you can look it up on your CustomerSource account.
Customers migrating from Microsoft FRx to Management Reporter 2012 will need to install Management Reporter V2 Service Pack 2 first. See related downloads section of the downloads page for location and instructions for installing Management Reporter Service Pack 2.
The following blog posts have more resources and tips for migrating.
We recommend that you contact your Microsoft Dynamics Partner before installing and that you verify that your environment is compatible. We also recommend you run FRx and Management Reporter 2012 side by a side for a while.
You’re new to Management Reporter but ready to get started….
Some of you may have been solving your financial reporting needs with another solution altogether, but now want to implement Management Reporter with your Dynamics solutions.
Contact your partner to determine if you already have Management Reporter registration keys or if you need to purchase them. Most Dynamics GP and Dynamics SL customers will already have registration keys, while most Dynamics AX customers will need to purchase Management Reporter before they can use it.
Then download Management Reporter and start designing your new financial reports.
dynamicscpm: Management Reporter 2012 Released! Blog bot DAX Blogs 0 31.03.2012 23:11
dynamicscpm: Learn more about Management Reporter and Forecaster at Convergence 2012! Blog bot DAX Blogs 0 16.03.2012 00:11
dynamicscpm: We're reading and responding to your Management Reporter suggestions -- Management Reporter 2012 Feature Highlight Blog bot DAX Blogs 0 12.03.2012 23:11
Часовой пояс GMT +3, время: 12:08.
