Старый 28.04.2012, 10:11   #1
ax_gfm_framework_team: Extending the Source Document Framework
Источник: http://blogs.msdn.com/b/ax_gfm_frame...framework.aspx
The upcoming series of blog entries is created to help developers new to Source Document Framework flatten the learning curve and quickly get up and running with their own source document extensions.
The information presented here is covering the mainstream scenario.
It is divided into 6 steps:
Step 1: Prerequisite - create your document
Step 2: Perform initial wiring to Source Document Framework – tables and maps
Step 3: Perform initial wiring to Source Document Framework – document classes
Step 4: Add Source Document Framework forms to your document UI
Step 5: Add code to distribute and journalize source document amounts
Step 6: Implement confirmation/posting of your document
ax_gfm_framework_team: Step 2: Perform initial wiring to Source Document Framework – tables and maps Blog bot DAX Blogs 0 28.04.2012 10:11
ax_gfm_framework_team: Step 1: Prerequisite - create your document Blog bot DAX Blogs 0 28.04.2012 10:11
Часовой пояс GMT +3, время: 00:26.
