Старый 25.07.2012, 21:11   #1
sashanazarov: AIF: Mind auto-generated Axd&ltDocumentName&gt.findCorrespondingAxBC method
Источник: http://sashanazarov.blogspot.com/201...xd-method.html
Problem
You have just created a document service with the wizard. You need the document to contain an unbound value. So, you create a display method on one of the tables, and add a corresponding parm-method to Ax class. Then you refresh the services, but the new field is not presented in the schema.
Solution
Check the new Axd class. By default, it may have findCorrespondingAxBC method, overriding the base class method and always returning classnum(AxCommon). This is why your new parm-method in the Ax class is ignored.
P. S. There are actually TODOs added to the auto-generated methods. It may be a good idea to clean up the TODOs first, and then continue with the service development.
axStart: AIF tuning & testing Blog bot DAX Blogs 0 01.04.2011 13:11
jinx: Dynamics AX AIF Webservices – Date, Time und Datetime Datentypen Blog bot DAX auf Deutsch 0 12.06.2010 01:05
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Kashperuk Ivan: How to quickly set up Application Integration Framework (AIF) for testing Axd documents Blog bot DAX Blogs 0 07.11.2009 14:05
Dianne Siebold: AIF Queries & Schemas: A Picture is Worth a Thousand Words Blog bot DAX Blogs 0 12.09.2008 02:05
Часовой пояс GMT +3, время: 10:41.
