Старый 21.10.2012, 22:13   #1
emeadaxsupport: AX 2012 Database: How to enable SQL compression (Enterprise edition)
Источник: http://blogs.msdn.com/b/axsupport/ar...e-edition.aspx
Description:
We now fully support database compression from within the AX system. If you are running Enterprise Edition, you can apply compression, which will save you Storage Space and decrease time for backup and restore.
Read about the feature in the links section below.
How to:
The form SysSQLSetup is used to set the compression and index options. This form can only be found in the AOT.
To set the right compression level Page or Row, please read the added link below.
Apply the settings on either All tables and indexes or individual selection.
In the form SysSQLAdmin, which can be found in the main AX menu (System Administration / Periodic / Database / SQL Administration)
we can apply the compression changes to all indexes or tables.
Recommendation:
Apply only compression off hours or best in the implementation fase.
Links:
Data Compression: Strategy, Capacity Planning and Best Practices
http://msdn.microsoft.com/en-us/libr...=SQL.100).aspx
Supported on:
SQL 2008 & SQL 2012 Enterprise
AX 2012
Author: Kim Truelsen
Date: 21/10-2012
emeadaxsupport: Unable to deploy AX 2012 Reporting Extensions on SQL Server 2012 Reporting Server Blog bot DAX Blogs 0 26.06.2012 23:12
emeadaxsupport: How to print production instructions for Kanbans in AX 2012 Blog bot DAX Blogs 0 11.05.2012 04:12
emeadaxsupport: Dynamics AX 2012 Prerequisite Check Utility and SQL Server cluster Blog bot DAX Blogs 0 20.03.2012 19:11
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
Часовой пояс GMT +3, время: 07:14.
