Старый 25.10.2012, 13:11   #1
kamalblogs: Programming Improvements with Dynamics Ax 2012 R2
Источник: http://kamalblogs.wordpress.com/2012...cs-ax-2012-r2/
This was one of the very interesting session we had . As a developer it was really exciting to see how we can scale the application further.
LINQ:
- Though the .net integration worked well with through Ax proxies there was a void when it comes data acess.
- The X++ team has come up with a LINQ provider that will fill up this gap.
- Highlevel: X++ LINQ Provider will create a search tree based equivalent for the C# search tree created through LINQ
-What this means ? You can access data from AOT Tables through LINQ with just few lines of code, something like the one below.
//Pseudo not exact syntax QueryDataProvider query = new QueryDataProvider('TableName'); //Rest the regular Linq Syntax applies
- Since LINQ Queries are composable the data once fetched can be applied with multiple composable ranges further E.g
QueryDataProvider query = new QueryDataProvider('select custtable'); var results = from qr in query select new (q.custaccount, q.custName) //prints the all the customer records foreach (var result in results) { Console.WriteLine(result); } //basically for a single result set fetched in query //you can apply multiple select criteria later to fetch data //This is like narrowing a search result further var results = from qr in query where qr.custName like 'Test*' select new (q.custaccount, q.custName) //prints the all the customer records foreach (var result in results) { Console.WriteLine(result); }
- You can filter based on expressions
- Field list concept is no more applicable. The choice of fields is automatically decided by the linq framework based on the conditions applied in each case.
- query is not executed untill the results are fetched.
- Folks, the advantages mentioned here are just to give you a feeling but it is limitless. All advantage that LINQ has brought in to the C# space is now applicable for data access to X++ tables.
- Remember this is LINQ Provider on the C# end and not on the X++. Means basically it works for the Visual Studio Projects
- LINQ Project Portal - http://msdn.microsoft.com/en-us/libr.../bb397926.aspx
- Keep watching the X++ team blog as Peter Villadsen who detailed this has promised to put more examples here
LINQ – Points to note
Solver Foundation
- OR(Operation Research) issues like the travelling sales man problem, transportation problem can be solved with the help of solver Foundation
- Solver Foundation is a mathematical modelling API brought in place by Microsoft. Solver Foundation is sold seperately to customers (Read more here).
-But the Good!!! news is that it comes fully licensed with Dynamics Ax
- Leverage this Solver Foundation to solve problems concerning with Optimization(Shortest Route), Bin Packing(Optimal allocation)
- The dll is present in the Dynamics Ax installation(Client i guess) and you can just add it to your reference and get to use it.
- Solver foundation is used by standard Dynamics Ax in constraint based product configurator.
Code Upgrade Tool
- Microsoft is trying to see how it can reduce the pain of code upgrade with rollup and major releases. CUT is an outcome of this exercise.
- This is very very powerful, as AST(Abstract Syntax Tree) is created for the X++. (Similar to Roslyn Project for C#)
- What is an AST ? AST is a DOM(XML sort of) representation of a method or a class.This means the variables in a class could just be a node in the DOM and can be easily queried. Similarly expressions, Types etc.
- How does this help ? unlike the X++ parser output the output of AST is simple, structured, queryable. Which means you can easily manipulate code based on Rules..
- E.g:
- All methods must have a access specifier, if not an access specifier is entered automatically
- If there is a IF condition it must have braces around
- Format the code
Architecture
- What it has to do with Code Upgrade ? Means, the system will try to better manage automatic merge and simplify the process. The CUT tool that is to come will create automerged objects and put it in a patch layer(not sure if it is patch). Then one can review to decide to keep the changes or eliminate them
- What other use AST has ? The Life cycle tools that are built my Microsoft relies on the AST to analyze the code metrics.
- Can i use it for older versions ? No it can’t be used. Since AST can’t be built for older versions.
- When is CUT available ? Not confirmed as of now.
Code Upgrade tool (AST visible on the left)
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 09:58.
