Старый 27.12.2012, 00:15   #1
emeadaxsupport: Netherlands VAT report is displaying the old VAT rate '1a Belast met 19%'
Источник: http://blogs.msdn.com/b/axsupport/ar...st-met-19.aspx
Since October 1st 2012 the Netherlands VAT rate has changed from 19% to 21%. In order to update the NL VAT report in AX2009 & AX2012 to reflect this, the text on the VAT report needs to be changed from
'1a Belast met 19%' to '1a Belast met 21%' for the Tax reporting code 110
Here is the procedure how to do this for Dynamics AX 2009 and AX 2012
AX 2009
1. Go to the AOT\Reports\TaxReport_NL
2. Locate the method ''makeReport' and on line 9 change the text '1a Belast met 19%'; to '1a Belast met 21%
3. Save
AX 2012
1. Go to the AOT\Classes\TaxReportController_NL
2. On this class go to the method 'Fetch'
3. In here edit the label "@SYS310883'(rightclick on the label in the code and select lookup label/text) on line 20 for the language NL so that the label reflects the new VAT %.
4. Save
emeadaxsupport: "Parameter is missing a value" error running a customized report in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 21.11.2012 00:12
emeadaxsupport: "An exchange rate cannot be found for exchange rate type XXX between currencies YYY and ZZZ on exchange date." when you attempt to process in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 26.09.2012 07:15
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
sumitsaxfactor: Report Design and Controls Blog bot DAX Blogs 0 05.09.2012 22:11
Часовой пояс GMT +3, время: 11:41.
