Старый 30.01.2013, 22:12   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Terms of payment has setup for 30 days of the next month
Источник: http://blogs.msdn.com/b/axsupport/ar...ext-month.aspx
The problem is in AX2012 when the Terms of payment has setup for 30 days of the next month. If we create the Invoice journal in a month, which has 31 days (e.g. August), the Due date is calculated OK (30th of September). If we create the Invoice journal in a month which has 30 days (e.g. September) the Due date is calculated incorrect + 2 months (30th of November), but should be October.
The Workaround you can find in the attached file.
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
emeadaxsupport: How to remove notifications (EventInbox) older than one month Blog bot DAX Blogs 0 10.10.2011 17:11
Dynamics AX Sustained Engineering: Terms of Payment do not behave as expected when Finance II is not licensed Blog bot DAX Blogs 0 15.04.2011 20:12
emeadaxsupport: Unable to deploy AX 2009 Enterprise Portal on SharePoint 2010 even after patching setup files with hotfix 2278963 Blog bot DAX Blogs 0 08.12.2010 03:14
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
Часовой пояс GMT +3, время: 03:26.
