Старый 14.03.2013, 02:23   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Ax2012R2 Report does not display any records in Report Viewer
Источник: http://blogs.msdn.com/b/axsupport/ar...rt-viewer.aspx
Issue:
No information is displayed in report viewer for a customer report
Reason:
In this situation an image was added to the report footer for the purpose of an electronic signature. When this image was removed from the report, the report did print correctly. After further investigation it was found the image was 'corrupted', a different image was utilized and the report printed correctly.
emeadaxsupport: The Report Server Configuration ID could not be found in the SRSServers table Blog bot DAX Blogs 0 09.10.2012 17:11
emeadaxsupport: Cycle counting list report does not display warehouse and locations Blog bot DAX Blogs 0 19.09.2012 20:11
emeadaxsupport: AX 2009: The “Goal” value in the Profitability Analysis report on RoleCenter page pages does not show the budgeted values Blog bot DAX Blogs 0 05.04.2012 14:11
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
Часовой пояс GMT +3, время: 03:56.
