Старый 17.04.2013, 03:25   #1
bojensen: SRS report does not reflect the new query changes – cache issue [AX 2012]
Источник: http://blogs.bojensen.eu/?p=4697
In some scenarios you may see that your query changes doe not reflect in the report. This is due to some caching that is done. The obvious thing is to delete the AUC files and clear out your data usage. But there is a new table that we need to be aware of in this [...]
bojensen: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] | Sreenath Reddy G – Dynamics AX Consultant’s Blog Blog bot DAX Blogs 0 15.03.2013 17:11
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
sumitsaxfactor: Report Design and Controls Blog bot DAX Blogs 0 05.09.2012 22:11
emeadaxsupport: SRS Report CustAccountStatement is hanging with Suspended Process in AX 2012 CU-2 Blog bot DAX Blogs 0 17.05.2012 06:13
Часовой пояс GMT +3, время: 21:56.
