Старый 11.09.2013, 17:11   #1
kamalblogs: SSRS Tip: Speed up RDP based SSRS reports testing in Dynamics Ax 2012
Источник: http://kamalblogs.wordpress.com/2013...amics-ax-2012/
When working on precision designs a lot of time is spent on waiting for the preview to run. If your precision design uses an RDP dataset here is a simple and fantastic tip to speed up.
1. Convert your temporary table to persistent by modifying the TableType property to Regular
2. Now run the report once. Either from Visual studio or inside Ax. This fills the data in the temporary table.
3. Comment the code inside processreport method or simply write a “return” statement on the first line of the method.
That’s it. you are now geared for a faster execution of the reports. Remember to revert back once you are done or wait for the testers to find it but don’t let it go to the production.
For more tips and learning about SSRS – AX 2012 order the book Dynamics AX 2012 Reporting Cookbook authored by me.
Related articles
ax-erp: Get list of printers in Dynamics AX 2012 for SSRS reports [Using X++] Blog bot DAX Blogs 0 19.07.2012 18:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
dax-lessons: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] Blog bot DAX Blogs 0 06.09.2011 00:12
dynamics-ax: Expert SSRS with AX Tip from Michael Stashwick Blog bot DAX Blogs 0 14.01.2011 05:18
Часовой пояс GMT +3, время: 10:04.
