Старый 09.01.2014, 17:11   #1
palleagermark: Need to drag and drop files or text into AX 2012?
Источник: http://www.agermark.com/2014/01/need...s-or-text.html
In AX versions before 2012, Microsoft shipped a small ActiveX component that you could add to forms in order to be able to drag files onto the form and get the filepath and name of the file.
That ActiveX is not distributed anymore. The feature can be replaced by using Windows Presentation Foundation (WPF) controls, and you can see examples of that in the forms SMMDocuments and SMMEncyclopedia.
Here is a small form with samples on how to catch files and text being dropped on a control: Download from SkyDrive
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
atinkerersnotebook: Using Excel to Import Customers and Vendors in Dynamics AX 2012 Blog bot DAX Blogs 0 19.07.2013 15:11
Gareth Tucker: Global Search Add-on Alternatives for Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 24.07.2012 14:11
dax-lessons: Easy drag and drop – files [Document Management] with minimum X++ Coding [Dynamics AX] Blog bot DAX Blogs 0 10.04.2011 08:19
Часовой пояс GMT +3, время: 00:10.
