Старый 28.02.2014, 04:47   #1
lcs: New Business Process Modeler features
Источник: http://blogs.msdn.com/b/lcs/archive/...-features.aspx
Today we released two new features in the Business Process Modeler. Here's what you need to know:
Remove gaps from a diagram
A common ask we hear from customers is a way to modify a diagram without creating gaps. You can now right-click any gap, and then select Remove gap from the app bar. The item will no longer be tracked as a gap. If you want to bring a gap back, you can just edit the item and a gap will be created again.
We also hope that this will help you model a broader set of business processes that cannot be performed in AX.
We've also set lines to no longer be gaps.
Open AX 2012 from a diagram
Have you ever been looking at a diagram, then gone and navigated to that form in AX 2012 for a demo or investigation? Now you can do this quicker than ever. Simply right-click a block in the diagram that was generated by task recorder and that corresponds to an AX form, and then select the Open AX 2012 button in the app bar. This will launch a click-once app which will launch the default AX 2012 client, and navigate to the appropriate page.
If you don't see the button on a particular block, it's most likely because we're not sure how to open the form. It may require some data as input that we're not yet sure how to provide.
We hope you enjoy the new functionality, and as always we look forward to your feedback!
Microsoft Dynamics CRM Team Blog: New eBook: How to customize a CRM business process Blog bot Dynamics CRM: Blogs 0 14.01.2014 04:16
atinkerersnotebook: Creating Lifecycle Services Business Process Models with the Task Recorder Blog bot DAX Blogs 0 08.12.2013 19:12
Microsoft Dynamics CRM Team Blog: Using the Business Process Flow Designer Blog bot Dynamics CRM: Blogs 0 24.10.2013 05:13
Gareth Tucker: CRM 2013 New Features: Business Process Flows Blog bot Dynamics CRM: Blogs 0 17.10.2013 04:36
dynamicsaxtraining: Purchase business process Blog bot DAX Blogs 0 07.12.2009 19:05
Часовой пояс GMT +3, время: 14:41.
