Старый 23.05.2014, 13:11   #1
emeadaxsupport: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId". The conflict occurred in database "YourDataBaseName_model", table "dbo.Model"
Источник: http://blogs.msdn.com/b/axsupport/ar...odel-quot.aspx
Given scenario:
You receive the following failure when compiling the application:
Cause:
This might be caused by some metadata pieces that have offending combination)
Resolution suggestion:
a. Disable the FK constraint from model database by running following SQL statement:
EXEC sp_msforeachtable "ALTER TABLE ? NOCHECK CONSTRAINT all"
b. Do a full application compile
c. Run the following SQL query to check the affected objects :
select top 100 *fromModelElementDatamed
where notexists
( select 1 fromUTILMODELSumwheremed.ModelId=um.IDandmed.LayerId=Layer)
d. Take necessary actions to correct the affected objects
e. Enable the FK constraint again on your Model Database by running following SQL statement:
EXEC sp_msforeachtable "ALTER TABLE ? WITH CHECK CHECK CONSTRAINT all"
f. Do a full XPP compilation and a full CIL generation
emeadaxsupport: Violation of PRIMARY KEY constraint 'PK_ModelElementData_ElementHandle' error installing some hotfixes on Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 08.01.2014 22:13
ax-erp: Choosing a Primary Key: Natural or Surrogate? Blog bot DAX Blogs 0 18.12.2012 02:11
emeadaxsupport: Error when upgrading to AX 2012 Feature Pack: The UPDATE statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId" Blog bot DAX Blogs 0 20.07.2012 00:11
Часовой пояс GMT +3, время: 13:16.
