Старый 19.08.2014, 17:23   #1
GetLucky is offline
GetLucky
99 / 13 (1) ++
Несколько вложений для письма. Нужен пример кода
Добрый день!
Есть код, который без проблем делает один аттачмент, но вот пару - никак.
Может кто-то поделится?
Вот мой код
        public void SendEmail(Entity PrimaryEntity, IOrganizationService service, Dictionary<string, string> FileNameDictionary)
            var ClientId = PrimaryEntity.Id;
            var ownerId = ((EntityReference)PrimaryEntity.Attributes["ownerid"]).Id;
            Entity owner = service.Retrieve("systemuser", ownerId, new Microsoft.Xrm.Sdk.Query.ColumnSet(true));
            String ownerName = (String)owner.Attributes["fullname"];
            String subject = "The document has been created by " + ownerName + "<br><br>";
            subject = subject + "The following document are required in the Contact.<br><br>";
            ActivityParty fromParty = new ActivityParty
                PartyId = new EntityReference(SystemUser.EntityLogicalName, ownerId)
            ActivityParty toParty = new ActivityParty
            Email email = new Email();
            email.RegardingObjectId = new EntityReference("contact", ClientId);
            email.To = new ActivityParty[] { toParty };
            email.From = new ActivityParty[] { fromParty };
                email.Subject = "Report";
                email.Description = subject;
                email.DirectionCode = true;
               foreach (var FileNameDic in FileNameDictionary)
                   email.email_activity_mime_attachment = new[] { AttachFileToEmail(FileNameDic.Key, FileNameDic.Value) };
/*email.email_activity_mime_attachment = new[] { AttachFileToEmail(FileNameDic.Key, FileNameDic.Value) };*/
            Guid EmailId = service.Create(email);
            SendEmailRequest req = new SendEmailRequest();
            req.EmailId = EmailId;
            req.IssueSend = true;
            req.TrackingToken = "";
            SendEmailResponse res = (SendEmailResponse)service.Execute(req);
		 public ActivityMimeAttachment AttachFileToEmail(string fileName, string OutputFileName)
            var fileLocation = OutputFileName;
            var stream = File.OpenRead(fileLocation);
            var byteData = new byte[stream.Length];
            stream.Read(byteData, 0, byteData.Length);
            var encodedData = Convert.ToBase64String(byteData);
            var extension = Path.GetExtension(fileLocation).ToLower();
            String mimeType = "application/vnd.openxmlformats-officedocument.wordprocessingml.document";
            var sampleAttachment = new ActivityMimeAttachment
                ObjectId = new EntityReference(Email.EntityLogicalName, EmailId),
                ObjectTypeCode = Email.EntityLogicalName,
                FileName = fileName,
                MimeType = mimeType,
                Body = encodedData,
            stream.Close();
            return sampleAttachment;
Трекинг факта открытия письма LisP Dynamics CRM: Разработка 1 11.03.2013 22:18
Глюк при отправке письма через E-mail Router bear1 Dynamics CRM: Администрирование 5 18.05.2012 11:20
вставить guid письма в тело письма lenkin Dynamics CRM: Функционал 2 28.09.2011 13:37
Какая максимальная длина темы письма? Tony Green Dynamics CRM: Функционал 1 05.03.2009 21:09
несколько баз MS CRM shumelka Dynamics CRM: Администрирование 5 01.03.2005 16:53
Часовой пояс GMT +3, время: 00:18.
