Старый 27.08.2014, 22:11   #1
emeadaxsupport: Microsoft Dynamics AX 2012 Mobile apps and Workflow approval via email.
Источник: http://blogs.msdn.com/b/axsupport/ar...via-email.aspx
Due to a recent change to the Azure Service Bus the following whitepapers are no longer accurate.
The following white papers are impacted:
http://www.microsoft.com/en-us/downl....aspx?id=36776
http://download.microsoft.com/downlo...ia%20email.pdf
In the sections titled
Creating a new Windows Azure Service Bus namespace
is not longer valid.
A update rolled on 8/24 did change the default behavior of newly created namespaces on the portal to support only SAS authentication. These steps work to create a proper service bus.
1) Install azure PowerShell
http://azure.microsoft.com/en-us/doc...re-powershell/
2) Connect the azure powershell to your subscription
add-azureaccount
3) Run New-AzureSBNamespace -name SBName -location 'east us'
changing your name and location. This will create the access control site properly. You should output similar to this.
Region : East US
DefaultKey : 2pRUX4K5EhE5XKvDsaS+816/Nrqzztkgur/CKsib40w=
Status : Active
CreatedAt : 8/26/2014 7:24:31 PM
AcsManagementEndpoint : https://SBName-sb.accesscontrol.windows.net/
ServiceBusEndpoint : https://SBName.servicebus.windows.net/
ConnectionString : Endpoint=sb://SBName.servicebus.windows.net/;SharedSecretIssuer=owner;SharedSecretValue=2pRUX4K5EhE5XKvDsaS+816/Nrqzztkgur/CKsib40w=
We are working to correct the official documentation.
Thanks as always.
dynamics-community.at: Verfügbare Mobile Apps für Dynamics AX 2012 Blog bot DAX auf Deutsch 0 18.11.2013 23:13
DAX: Introducing new native mobile device experiences Blog bot DAX Blogs 0 19.03.2013 19:11
Gareth Tucker: MyCRM add-ons for Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.07.2012 18:11
daxdilip: Review On Microsoft Dynamics AX 2009 Administration Book Blog bot DAX Blogs 3 26.04.2011 07:12
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
Часовой пояс GMT +3, время: 22:44.
