Старый 20.12.2014, 08:17   #1
Kashperuk Ivan: Tutorial: Auto-Complete functionality on form controls
Источник: http://kashperuk.blogspot.com/2014/1...nality-on.html
I guess all of you are familiar with the Auto-Complete feature present in Dynamics AX. Whenever you type in a repeated value in a control on AX forms, an automatic suggestion pops up next to the entered characters and the user can choose to accept the suggestion (for example, by tabbing out of the control).
There are methods on the form (specifically, the FormRun class) that provide you with a more tight control over the auto-completion list available to the user, and this blog post will describe the behavior of these methods, as there are a few not obvious things there.
Method signature Method behavior description getAutoCompleteString(int _elementIndex) Retrieve the auto-complete string saved under the specified index in the auto-completion list of the form.
The indexing is not control-specific, and is not very efficient at keeping the number of values in the list low, so you will see values from multiple controls here.
The method returns a container containing 2 values:
- the auto-completion string value
- the index of this string in the auto-completion list getAutoCompleteString(int _startIndex, FormControl _control, str _searchStr) Retrieve the auto-complete string for the specified control, finding the first one in the list starting from the specified startIndex + 1.
If _searchStr is also specified, it will find the first matching entry in the list with index > startIndex. This is the closest behavior to what happens when a user types in a certain character in the entry control on the form and the kernel needs to search and populate the auto-complete value for it.
Note: There’s a small bug in this function, where it does not return the full string value for longer texts. A workaround is to use the above “overload” and retrieve the full value by index. setAutoCompleteString(string _string, anytype _control) The first argument is clear, and that is the auto-completion string to add to the list of suggestions.
The second argument is presented as _control, but can accept either an instance of a FormControl, or an integer value of the list item index to set.
If the _string already exists in the auto-completion list for this control, nothing will happen. If it does not exist, a new item will be added to the list (number of items cannot exceed 300) with the next available index. setAutoCompleteString(string _string, anytype _index) The auto-completion list item at index _index will be updated in the list with the specified _string value.
This method “overload” basically allows you to override a particular value in the list with a new value. delAutoCompleteString() Deletes all auto-completion items from the list, regardless of which control they are bound to, if any. delAutoCompleteString(anytype _index) Deletes the item with the specified index from the auto-completion list. delAutoCompleteString(anytype _control) Deletes all auto-completion items for the specified control from the list.
When a value in one of the controls on the form is modified, this value is also automatically added to the auto-completion list. With the above methods, however, you can control, if this value should actually stay there, or be immediately removed.
This way you can, for example, restrict the user to only be provided with auto-completion hints from a certain list (similar to IntelliSense).
I created a simple form to demonstrate all the above methods in action.
Tutorial form to demo auto-completion capabilities
You can download the form from my OneDrive.
Apart from the above methods, there is also a global setting which allows you to control auto-completion list availability for a particular user. This is control on the User options screen, as highlighted in the below image:
User options form
If this check box is not set, auto-completion suggestions will not be shown to the user when entering data on forms, even though the auto-completion list is still maintained behind the scenes.
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Kashperuk Ivan: Tutorial: Brief description of ways to close a form in AX Blog bot DAX Blogs 1 02.07.2010 14:30
Dianne Siebold: AX Tutorials in the AOT Blog bot DAX Blogs 0 05.12.2009 10:07
Kashperuk Ivan: tutorial_Form_Dynalink (a small tutorial on dynalinks) Blog bot DAX Blogs 0 22.08.2007 17:00
Часовой пояс GMT +3, время: 12:55.
