Старый 20.03.2015, 16:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Moving AXModelstore from Source environment to Target environment with different DB collation
Источник: http://blogs.msdn.com/b/axsupport/ar...collation.aspx
AX 2012 RTM/R2/R3
We have in support received some queries for recommendations moving the AXModelStore to a database with different collation.
Conclusion:
The AXModelStore file we create is specific to SQL_Latin collations. There should not be an issue (we are aware of)
when we are importing the AXModelStore file from one (Source environment) to another (Target environment) having different collations.
However, we would recommend to have same collations to ensure that we don't run into any issue.
Axilicious:The given value of type String from the data source cannot be converted to type nvarchar of the specified target column. Blog bot DAX Blogs 0 17.03.2014 18:11
emeadaxsupport: Moving POS dlls from one machine to another causes the file to be blocked. Blog bot DAX Blogs 0 29.01.2014 22:12
emeadaxsupport: Possibilities to create Memory Dumps from crashing processes Blog bot DAX Blogs 0 12.05.2010 19:05
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
emeadaxsupport: Unable to install Dynamics AX 2009 Analysis extensions when the default SQL Server Analysis Server collation is set to Turkish_CI_AS or Turkish_CS_AS Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 05:56.
